Part Number: TAS2764
Other Parts Discussed in Thread: TIGER
Could you please provide Linux driver for TAS2764?
The Linux kernel version is 4.1.
Thanks and Best regards,
Tiger
Hi guys
kernel 4.1 is too old, our driver at least support 5.4 or above. lpaa-android-drivers/tasdevice-linux-driver - Unnamed repository; edit this file 'description' to name the repository.
One more thing, how many pieces of tas2764 will be used on one device.
Hi Shenghao,
I’m apologize for the delayed reply.
=> one device wiil have one piece of tas2764.
Our software's response to the comment is as follows:
Can you help check this driver codebase support TAS2764 ?
We can try to build on our 4.19 kernel
Sophia
You can try it, kindly post your issue if case of any compiling issue.
Here is the guideline: doc - lpaa-android-drivers/tasdevice-linux-driver - Unnamed repository; edit this file 'description' to name the repository.
One more thing, I want to collect some information.
What's the sample rate, channel bitwidth, audio sample bit width? i2s or tdm? Thanks.
Hi Shenghao,
We will try it, thank you for your help.
Regarding the questions, I'll reply a bit later.
Hi Shenghao,
We use i2s.
Sample rate: 48kHz
Channel bitwidth: 32bit
Audio sample bit width: 24bit
Thanks.
