Other Parts Discussed in Thread: TAS5825P, TAS5825M, TAS5825PEVM
Hi TIer
Customer use our TAS5828 and to change the left and right by our software.
from
to
But the setting is not work.
Could you help find the solution?
Hi TIer
from
to
Hi jesse
Could you help me check it on the EVM board?
Thank youhttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/6/20230225_2D00_ok.ppc3
hi, Tony
the ppc3 file you used belongs to TAS5825P, not the tas5828.
can you share me the tas5828 ppc3 file?
tks
jesse
Sorry , customer actually use the TAS5825P.
So could you help me to check this ppc3 file.
hi,
so customer's issue happen at tas5825p or tas5828.
if customer use tas5828 with tas5825p gui, then of cause it will have problem.
please let customer change to use tas5828 GUI.
this 2 devices' registers are not the same.
they cannot use same GUI.
tks
jesse
Customer use tas5825 chip and use tas5825EVM software . I make a mistake put this question in tas5828p forum.
So can tas5825p and tas5825M control in same sofware?
