Part Number: PCM3070
I want to use the "DRC with Control" processing block in PPS for setting a DRC configuration for only a specific frequency range (I believe this is the right processing block for doing this). But how exactly is the control function used (the inputs on the bottom of the block)? What would I connect to these two inputs? Could I use a Biquad on the control inputs for setting the frequency range that I want subject to the DRC? The help page doesn't seem to clarify this. Please correct me if I am overlooking something.
Thank you,
Goose
