Part Number: TLV320AIC3101
Hi team,
Recently we found a random issue in customer side. After power up, TLV320AIC3101 occasionally can't output normally and the speaker has no sound. But we checked the I2S and it's normal. And then we checked the power up sequencing, it also follow the requirements in datasheet. And the design is an old design in customer. Previous PCBs never report this kind of issue.
When the issue happen, we tried to rewrite all registers but can't work. then we tried RESET again, it work.
I suspect that when the issue happen, AVDD isn't power up properly. But from the power up sequencing ( shown in below), there isn't any problem.
I was wondering if you ever met such issue. And what is the root cause here? what we should do next? Thanks!
Rayna
