Hi Expert,
Want to check that if I use two TAS5825M for 2.2ch design, for PVDD cap selection, what's minimum cap I can use?
Because we have board size concern. From datasheet and EVM, use 390uF but the size is too big.
Thanks.
Hi Expert,
Thanks.
Hi Bo
For simplify, when there's 1A PVDD current needed, and the capacitor using 100uF, you'll get around 1V ripple voltage with audio frequency. The ripple voltage ratio to the PVDD current, and inverse to the capacitance. Usually suggest to keep PVDD-1/2ripple voltage still higher than your output power requirement, otherwise the output THD will decrease from clipping.
