HI,
I was reading the documentation of the USB DONGLE design (CC2531) and in regards to the IFA_USB PCB antenna it stated that:
"To compensate for a thicker/thinner PCB the antenna could be made slightly shorter/longer"
In the reference USB dongle design, the pcb thickness is 1mm while the pcb thickness for CC8531 kit is 1.6mm which uses the Inverted F Antenna.
My question is would the IFA_USB be compromised if it was placed on a 1.6mm thick pcb? I am asking because I desire to panelize my designs but the IFA_USB and Inverted -F antenna are using different board thickness.
Thanks as always for the prompt responses!
Yohan
