Other Parts Discussed in Thread: LM4864
When using LM4865, there is pop issue when switching on/off, the schematic is shown as below. The customer wants to konw how to address this issues.
Hi Ethan,
Can you test by shorting the input side of C11 to GND? This should at least help identifying if we should check the components close to LM4864 or is it related to the connection from the audio source into the AC coupling capacitor.
Have you tried with lower gain? Seems you have 6V/V now, do you need this higher gain or could it be reduced to 2V/V or so?
-Ivan Salazar
Applications Engineer
Hi Ivan,
I have shorted C11 to GND, the pop becomes small however the sound become larger.
Lower gain can reduce pop, however, we need 6V/V gain to defeat our competitor, who has large gain and small pop.
Do you have other suggestions? hope to receive your feedback.
BR,
Ethan
Hi Ethan,
What does "sound become larger" means on this case? If C11 is shorted to GND there should be no sound?
-Ivan Salazar
Hi Ivan,
Sorry, my description is wrong. When I shorted C11 to GND, the pop becomes larger.
Hi Ethan,
Understood, can you try by shorting R23 to BYPASS pin, similar to IN+? Does that reduce the pop?
How is Bypass ramping up and down during power up/down?
-Ivan Salazar
