TPA2033D1: TPA2033D1
Part Number: TPA2033D1
Hello, we use amplifier TPA2033D1YZFR . What is the minimum resistance of speaker, that will not cause damage to amplifier?
  • Hi Pavel,
    The minimum impedance used for spec is 4Ω.
    Using lower impedance load would most likely not cause damage, however the device will heat up faster and the performance described in the data sheet would not be met.
    -Ivan Salazar
    Applications Engineer
