Hello Audio Team!
My customer has a few questions related to the VBAT_IN pin used for input diagnostics on this device.
Thanks for the help!
- Andy
Hi Andy,
1. That is correct. The VBAT_IN pin is used solely for diagnostics in this device and does not support load dump. We suggest stepping down the voltage with a converter or using a voltage divider.
2. No, however, we recommend VBAT to be greater than the programmed MICBIAS voltage. This is to reduce the likelihood of false detection for certain faults. Explained further in PCM6xx0-Q1 Fault Diagnostic Features
3. Less than 5 uA.
