Hi ti team,
Using TAS5805M for mono 1.1. Split the low frequency range to 60HZ-4KHZ, and discard the rest of the frequency range. We found that the TAS5805M frequency drops suddenly at 2KHZ-3KHZ. What is the reason for this? Under the same test conditions, the competitor ACM8625 does not exhibit this behavior.
The green curve represents the TAS5805M, and the red curve represents the ACM8625.
hi switch
can customer share us the ppc3 file?
what is the cross frequency for mono1.1?
tks
jesse
hi switch
the DRC setting in tweeter should turn on low and mid band.
just enable high band will make the low and mid band be filtered by DRC.
tks
jesse
