Part Number: TAD5242
Is any recommended an audio differential amplifier for OUT1P,M and OUT2P,M outputs?
Best regards
Jan Kruczalak
Best regards
Jan Kruczalak
Hey Jan,
This question is not very clear. Is any 'what?' recommended for what exactly ?
It sounds like you are trying to find out if the out1p,m and out2p,m can playback differential outputs?
Ore.
I know out1p,m and out2p,m can playback differential outputs.
I want to apply an audio amplifier with a differential input and a single ended output.
Best regards
Jan
Correct, out1/2p,m can playback differential outputs.
Do you mean you want to mix the differential output stage into an audio amplifier that would produce a single-ended output ?
If yes, that is a typical application, but I would only support helping you get the differential output signal out of the DAC device. If you need help getting that differential signal out I am more than happy to help.
Customers are generally responsible for their design decisions not TI, but we welcome schematic reviews and any questions regarding troubleshooting the device.
Ore
Hey Jan,
Is there a schematic that you could provide to help me understand the query?
Or provide a better description of the signal path.
Ore.
