Other Parts Discussed in Thread: TAS5548
Hi ti team,
Help find the reason why WS6.2 has noise at 283Hz.654 WS6.2 uses TI chip TAS5548 + TAS5634 scheme,
noise is detected at the frequency of 283Hz. Please refer to the following screen capture.
The TAS5548 0x51-53 register will make noise if the following values are used. The default values are fine.
We have written the following register values to the TI TAS5634 EVM board and the same noise will appear.
The customer said that the following registers did not do EQ boost, so there should be no noise. Please help to check the cause and whether there is a solution. Thank you!
Current value of the ws6.2 register 0x51-53 |
51 00 7F EE 47 0F 00 23 72 00 7F EE 47 00 FF DC 7B 0F 80 23 5E |
52 00 7F DD FC 0F 00 EA 9A 00 7F 39 14 00 FF 15 66 0F 80 E8 F0 |
53 00 80 04 7E 0F 00 6B 69 00 7F 90 73 00 FF 94 97 0F 80 6B 0F |
The default value of register 0x51-53 |
51 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |
52 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |
53 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |
