TPA3118D2-Q1: How can I use the TPA3118D2-Q1 with Single-Ended Inputs
Part Number: TPA3118D2-Q1
Other Parts Discussed in Thread: PCM1754-Q1, PCM1789-Q1
Hello ,
I want to use  TPA3118D2-Q1 with a single ended DAC , for exemple the PCM1754-Q1
is it possible or do i have to use a differential analog output DAC like the PCM1789-Q1 .
Do i simply connect LINN and RINN of the TPA3118D2-Q  to GND ?  will that affect the signal in any way?
