TLV320ADC5140: SNR vs input amplitude
Part Number: TLV320ADC5140
customer need a picture of SNR vs input amplitude like below, can we provide?
  • Hi Anderson,
    We don't have SNR vs input amplitude because it's mostly redundant information. The SNR spec provided is measured with grounded (-infinity dBFS) input. So the SNR magnitude would lower by the same amount as the input signal.
    The only reason a customer would want this is to confirm that the SNR doesn't suddenly change at a certain input level. The THD+N vs amplitude graph can confirm this.
    At lower amplitudes, the harmonic content is 0, which means THD+N = SNR. As you can see the graph is flat, meaning the noise floor of the device does not change depending on input level.
    Jeff McPherson
