Hi Sir,
My customer use PCM1754 and they find pop when LRCK signal is start and stop. Is there any suggestion about their circuit design to prevent the output level shift question? Thanks for your kindly help.
Gary Teng
Hi Sir,
Gary Teng
Hello Gary,
Please refer to the following post regarding pop noise in this device.
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/956405/pcm1754-q1-pop-noise-issue
On a separate note, if possible I would use a simpler schematic at the output of the DAC for filtering stage ( something like the one that I have attached below. You can add more stages as needed, but this is a good and simple starting point)
Arash
