Hi ti team,
There is no TAS5731EVM available for purchase on TI's official website. Is there any alternative that can be used to debug TAS5731? Thanks
Hi Switch,
This EVM is not being made. You will need to make your own board to do this using the guides in the datasheet and EVM users guide.
Ramsey
Hi Ramsey,
TAS5731 power-on timing and shutdown timing do not conform to the Datasheet, please help assess whether there is a risk?
Boot timing: TPDN~RESET timing does not meet specifications, the measured value is 2.86s; Specifications ≥100us;
Shutdown timing: REST-I2C timing does not meet specifications, the measured value is 70ms, the specification requirements are ≥2us;
Hi Switch,
The datasheet specs should be met. We cannot guarantee proper functionality if run outside of this range.
Ramsey
