Part Number: TAS5731M
Regarding the power-on timing of the 5731,
1. At present, our AVDD/DVDD(the two power supplies use the same) will be later than PVDD, but we can ensure that the two power supplies are stable, and then pull up PD and RST, may I ask in this case, AVDD/DVDD is later than PVDD, will there be a problem? (The specification requires AVDD/DVDD to be earlier than PVDD);
2. The specification requires that PD should be raised first, and then RST should be raised. At present, we have no spare GPIO to control RST, RST will be raised after powering on, PD will be later than RST, and 5731 will be initialized after PD is raised,would that be a problem?
