Part Number: OPA1622
I am unable to find a dimensioned package drawing fore this device. The package name is VSON (DRC). I have checked on your website and the datasheet obviously.
Can you please help.
Hi Philip,
You can find the CAD drawing, footprint and 3D model in the link below.:
The device is 3x3, 0.5mm pitch and 1mm max height.
Chris Featherstone
Hi Philip,
To follow up I opened up the model in Altium and made measurements as shown below. You may verify with the model I provided in the link from my last post. I hope this helps.
Chris Featherstone
Hi Chris.
Thanks for your help here... However.
I use an IPC-7351 calculator that creates a footprint according to that industry standard. For that I use the actual component geometries. This is typically included in all datasheets or an ancillary drawing.
The links are to an already defined footprint and 3D model which isn't something I would use. The other link only shows a 3D render and not the geometric data.
There must be a drawing for the VSON (DRC 10) at TI.
Every component has one.
Phil
Hi Phil,
I am currently not finding a drawing. I will continue to look. In the mean time I found one more set of data that may help while I look. The VSON 10 is the table in the link below.
https://www.ti.com/lit/sl/sszb138a/sszb138a.pdf?ts=1724724419098
Chris Featherstone
Hi Phil,
Looking at a previous inquiry another engineer found it. I am attaching below.
0410.DRC10_ePOD_4218878_datasheet.pdf
Chris Featherstone
Excellent news. Thanks Chris & colleague. Much appreciated.
Would hate to have had to go find a suitable substitute based on simply because I couldn't create the footprint.
Thanks again.
Phil
Hey Philip,
No problem! Let me know if I can be of further assistance.
Chris Featherstone
