DRV134: Signal Balance Ratio(SBR) and Common Mode Rejection(OCMR)
Part Number: DRV134
I am checking the datasheet parameter of signal balance ratio(SBR) in positive value (i.e. 54dB). Generally, higher negative value indicates better common mode rejection. But here both min & typ values are in positive. What I misunderstood? please let me know your suggestions.
Similarly, common mode rejection values are represented same in positive. Could you support me to clarify on this spec?
thanks,
Dinesh
