PCM1794a
Other Parts Discussed in Thread: PCM1794A
Does the current segment DAC for the PCM1794A operate at the system clock? if not does it operate at 8*192KHz=1.536MHz for 192KSa/s sampling rate?
The DAC (I assume is sample and hold) will have a sinc response and I want to know what kind of accuracy hit I will incur in the passband.
What system clock rate do you recommend I use?
