PCM6020-Q1: SNR & THD+N Measurement
Part Number: PCM6020-Q1
Hi TI Expert,
Could you kindly share some material with me about how to measure the THD+N & SNR of the PCM6020-Q1?
Looking forward to your reply.
Thank you.
  • When we test Mic signal of the PCM6020, How to test the SNR and THD+N?
  • Hi Evan and Wilson,
    Both measurements are recommended to be measured with audio test hardware. These tools have functions built in to measure these things.
    THD+N is measured with the following 10log10(Signal_Power/Noise_and_Harmonics_Power) or 20log10(Signal_Voltage/Noise_and_Harmonics_Voltage). Usually this is done by putting a very narrow bandpass filter around the signal tone to measure its power/voltage and then using a notch filter to remove the signal tone and measuring the remaining noise/harmonics. According to the data sheet, the signal tone must be -1dBFS and the noise bandwidth is 20-20kHz
    SNR is a lot easier. This is done by grounding the input pins and measuring the resulting output value. This will be equivalent to the noise floor of the device.
    Jeff McPherson
