Current consumption on CC8520 in low-power mode
What is the expected current consumption in power down state?  Datasheet has it at 1A -- I assume it is a type and should be 1uA.  Please confirm.
We see more like 110uA and are looking for the leak.  The latest FW release has the following known issue:
[FW] The MOSI pin should be held high during power-down to avoid current leakage through the internal pull-up resistor
How much current leakage goes through this pull-up?  How about any other pull-ups?
Any other places where we might have a leak?
Vlad
  • Hi Vlad,
    The power consumption is really should be 1uA, it is wriiten in datasheet Rev. D,
    "ELECTRICAL CHARACTERISTICS" table (probably a typo in an early version of this document).
    By searching the document, I haven't find any reference to a value of SPI pull-up resistor, or any other
    pull-ups.
    At least to measure (and eliminate) the current draw from a MOSI pin, you can configure this pin to low
    and then high, and see what is the value of this specific pull up...
  • Yes, all the extra current leakage was due to MOSI pin.  Once it is handled correctly, the consumption drops below 1uA -- Incredible.  Good job guys.
    Also, the data sheet is correct.  But if you are viewing PDFs on a Mac Previewer, the "micro" symbol does not come through.
