Other Parts Discussed in Thread: NE5532
I need to determine the noise on the output of your op-amps at unity gain. Can you tell me what specs you provide that will allow me to calculate this? Clearly, Equivelent Input Noise will not work for this as it is measured at high gains. I have considered using the THD spec, but it apperas that this measured by throwing away loop gain, measuring THD and then extrapolating the result.
If there are no specs I can use for this, can you tell me how various families compare for low gain output noise?
Mitch
