Other Parts Discussed in Thread: TAS5825-SW
I am planning an 8 channel board design using four TAS5825M chips on a common I2C bus, each set to a unique address. The working plan is to use PPC to arrive at unique .cfg profiles, including EQ, etc. and store those on computer drive. A web browser interface running on the micro-controller will allow the configuration engineer to select a unique .cfg for each of the 4 chips. These will then get transferred to on-board flash. Upon power up, the micro-controller will read its flash and load the .cfg data into each of the four TAS5825M chips.
Do you see any issues with this approach?
James
