PCM5242: PurePath console 2 Configuration register dump
Part Number: PCM5242
Is there a way to dump the HybridFlow configuration built from PurePath Console 2 without using a dev kit?
I currently have 5x PCM5242 on a prototype board that works perfectly but need to try custom filters.
iWhat I have here is a PurePath console 2 and 3, a non-TI PCM5242 based board and an AC_MB DC058 RevA motherboard used for and ADC tests.
can you help me please?
Thank you
Claude
  • Hi Claude,
    As far as I know the PPC works with the device dedicated EVM. I don't know of any method that you can dump the hybrid flow build in without using the designated  kit. Specially PPC2 related boards are more restricted. Probably the easiest solution is to get the EVM and dump the registers and reuse it for your board.
    Arash
