TAS6511-Q1: How to use current sensing to verify if AMP works as expected
Part Number: TAS6511-Q1
Hi TI expert
In you AMP product, there is real-time current sensing result from the AMP to provide possibility to verify if AMP works as expected  from SoC side, then  how to use this current sensing result, for example, do we need to calculate CRC for it or bit comparison? and if this was done by SW, how much resource is need for this current sensing check( memory, CPU), assumed that 48KHz, 8bit audio data need to be checked.
can you also share the example from TI regarding how to check current sensing result.
thank you!
BR
Weicheng Li
