TAS6424E-Q1: SNR check
Part Number: TAS6424E-Q1
Other Parts Discussed in Thread: TAS6424E
Hi team,
Customer tested SNR with AP device and everything is good.
However, they tested it with multimeter and found it was about 16mV.
They cannot test every board with AP in production. They want to know if 16mV with multimeter is normal.
Peter
  • Hi Peter
    It would be mV level value when using oscilloscope to test, but no one could tell if it's correct behavior from this data.
    Oscilloscope is not precise enough to test this performance, the final value would largely decided by their oscilloscope type, probe type, parameter settings.  Form example, at my side when test nothing but probe itself to ground, it's already around 5mV RMS, from all kinds of environment noise. And test TAS6424E output, there's additional DC offset, would have another around 5mV.
