PCM1808: High output noise level
Part Number: PCM1808
Hi team,
On behalf of my customer, I would like to post a question to seek your guidance:
The wav file is captured using tinycap (bitrate 16, sample rate 48khz), as you can see in the screenshot between 5.0 and 6.0 sec in the white marked area, the white noise is high and permanent.
Our clock configuration:
- use in slave mode
- SCKI: 12.288Mhz
- LRCK: 48 kz
- BCK: 3.072 Mhz
Please let me know if you need any additional information. Thank you.
