TAS6684-Q1: Replacing TAS6584 with TAS6684
Part Number: TAS6684-Q1
I have replaced the TAS6584 with TAS6684 to increase the current output for out 1PBTL output. We have been evaluating the 6584 perfectly in this new product that we are developing. I have quickly reviewed and compare the datasheet side by side and tried just replace the IC on our board using same configuration header file we used for 6584.
My question is, Do I need to do some minor revision on the configuration file for the 6684 or we can just use the 6584 config as is?.
How about the PVDD shorted with VBAT below for 6584 in our schematic? Do I need to separate this circuit when using the 6684?
Im currently experiencing "ChOCDCFaultMemReg [0x8E]: CH1 OC - CH2 OC - c0" faut when I send play command to the board even at low volume setting. this is just by dropin replace the previous IC and not changing anything..
6648.codec_6584.h
rgds,
Jose
