TAS5805M: After the TAS5805 was written to the.h file, the output frequency response curve was measured. The result did not take effect.
Part Number: TAS5805M
Other Parts Discussed in Thread: TAS5805
PPC3 software was used to generate a.h file containing EQ and crossover, write TAS5805 and check the verification code,
and measure the voltage frequency response curve at the output end without any change.(Write not valid)
用PPC3软件生成一个包含EQ和crossover的.h文件,写入TAS5805并核对了校验码,测量输出端的电压频响曲线,没有发生变化。
