Part Number: TAS5828M
Other Parts Discussed in Thread: TAS5805,
Hi team,
I have a few questions.
In the Equalizer, EBE/DDE/DEQ, and DRC setup screens as shown below, there is a place to set a biquadratic filter.
I don't know how to calculate the filter coefficients for each filter type.
Can you please provide me with a formula for calculating the filter coefficients or a reference that I can refer to?
I do not understand how to set the Threshold Low, Threshold High, and Enrgy to DSP memory in the Threshold Setting below.
I assume that some conversion formula is used to calculate the values set for DSP memory based on the values set here, but I cannot derive the conversion formula.
I do not understand how to set each value of ratio and time constatnt below to DSP.
I assume that some conversion formula is used to calculate the DSP memory settings based on the values set here, but I cannot derive the formula.
Also, when I change Threshold, offset, and Ratio, the other values also change, but I would like to know what rules are used to change them.
Ryu.
