Hi expert,
do we have any difference between PCM6240 and PCM6340 in the software(any register difference or any special config) in the same condition.
Hi expert,
Hi Colt,
The PCM6xx0 family are all software compatible, sharing the same register map. The differences will show as a reserved bit if, for example, your comparing a 2CH ADC to a 4CH ADC. The extra 2 Channels will show as reserved bits for the corresponding register of the 2 channel device register map.
The primary difference between PCM6340 and PCM6240 is the supply pin for MICBIAS.
