Part Number: TPA3250D2EVM
Other Parts Discussed in Thread: TPS3802
The EVM uses the 15 volt bus derived from PVdd as a means to determine when PVdd has dropped below a specific value, thereby shutting down the TPS3250. In my application, the 15 volt supply will be coming from a separate power supply and therefore a drop in PVdd will not be detected.
Can I connect PVdd to the TPS3802 reset controller with a suitable resistive divider instead? I can add a zener clamp to ensure the input never exceeds 3.3 volts.
Thanks!
