Other Parts Discussed in Thread: TAS2505
Hi Team,
Customer want to make TAS2505 DOUT signal bypassing the DIN of I2S primary interface.
They used 1st example register setup in the SLAU472C reference guide, and modified some interface.
https://www.ti.com/lit/ug/slau472c/slau472c.pdf
They didn't use TAS2505 PLL part and clocked from their AP. (Page0, 0x04 --> 0x00) And set their MCLK and Sampling rate as 12.288M, 48kHz accordingly. (Page0, 0x0B --> 0x81)
Except above, they use 5.1 register setup. (5.1. Example Register Setup to Play Digital Data Through DAC and Headphone/Speaker Outputs)
For the interface setup, they tested each cases accordingly, but Secondary DOUT didn't output correctly.
/ * page 0 [R7 + M5 + N6 combination ] */ or / * page 0 [R7 + M6 + N5 combination] */ |
Could you guide how to change the register values to get correct DOUT data for bypass from the Primary DIN? (Echo back purpose)
Ernest
