Dear Devs
i got a board on a am437x with 2 tlv320adcx140-codec which we need to align in tdm i2s ... please see my dtb snippets below and tell me if that is supposed to work
this is basicly on a scarthgap yocto chain with 6.6 kernel
My problem is that the setup is not correctly registering.
I hacked the tlv320adcx140.c to register 2 different codecs too like this
static struct snd_soc_dai_driver adcx140_dai_driver[] = {
.name = "tlv320adcx140-codec0",
.capture = {
.stream_name = "Capture",
.channels_min = 2,
.channels_max = ADCX140_MAX_CHANNELS,
.rates = ADCX140_RATES,
.formats = ADCX140_FORMATS,
.ops = &adcx140_dai_ops,
.symmetric_rate = 1,
.name = "tlv320adcx140-codec1",
.capture = {
.channels_min = 2,
if (i2c->addr == 0x4c) {
dev_info(&i2c->dev, "probed c %d\n", i2c->addr);
return devm_snd_soc_register_component(&i2c->dev,
&soc_codec_driver_adcx140,
&adcx140_dai_driver[0], 1);
} else {
dev_info(&i2c->dev, "probed d %d\n", i2c->addr);
&adcx140_dai_driver[1], 1);
9.630738] tlv320adcx140-codec 1-004c: probed c 76
[ 9.645979] tlv320adcx140-codec 1-004d: probed d 77
[ 10.858609] asoc-audio-graph-card sound: loop on (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@1/endpoint)
[ 10.858761] asoc-audio-graph-card sound: Count As Normal (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@1/endpoint) (/ocp@44000000/interconnect@48000000/segme)
[ 10.858873] asoc-audio-graph-card sound: loop on (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@2/endpoint)
[ 10.858980] asoc-audio-graph-card sound: Count As Normal (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@2/endpoint) (/ocp@44000000/interconnect@48000000/segme)
[ 10.859069] asoc-audio-graph-card sound: loop on (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@1/endpoint)
[ 10.950494] asoc-audio-graph-card sound: loop on (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@2/endpoint)
[ 10.950714] asoc-audio-graph-card sound: loop on (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@1/endpoint)
[ 10.950818] asoc-audio-graph-card sound: link_of cpu_ep (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@1/endpoint)
[ 10.950860] asoc-audio-graph-card sound: link_of codec_ep (/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/tlv320adc5140@4c/port/endpoint)
[ 10.950910] asoc-audio-graph-card sound: is cpu
[ 10.951065] asoc-audio-graph-card sound: is codec
[ 11.019418] asoc-audio-graph-card sound: name is 4803c000.mcasp-tlv320adcx140-codec0
[ 11.019497] asoc-audio-graph-card sound: loop on (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@2/endpoint)
[ 11.019626] asoc-audio-graph-card sound: link_of cpu_ep (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@2/endpoint)
[ 11.019670] asoc-audio-graph-card sound: link_of codec_ep (/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/tlv320adc5140@4d/port/endpoint)
[ 11.019720] asoc-audio-graph-card sound: is cpu
[ 11.019810] asoc-audio-graph-card sound: error on graph_parse dai
[ 11.019819] asoc-audio-graph-card sound: error on cpu_ep (/ocp@44000000/interconnect@48000000/segment@0/target-module@3c000/mcasp@0/port@2/endpoint)
[ 11.019860] asoc-audio-graph-card sound: ret is neg
[ 11.019868] asoc-audio-graph-card sound: graph_for_each_link err
[ 11.019878] asoc-audio-graph-card sound: error -EINVAL: parse error
[ 11.019893] asoc-audio-graph-card: probe of sound failed with error -22
sound {
compatible = "audio-graph-card";
model = "Audio System";
label = "D880TSM093";
dais = <&mcasp1_port0>, <&mcasp1_port1>, <&codec_0_ep>, <&codec_1_ep>;
&i2c1 {
tlv320adc5140_4c: tlv320adc5140@4c {
#sound-dai-cells = <0>;
compatible = "ti,tlv320adc5140";
reg = <0x4c>;
pinctrl-names = "default";
pinctrl-0 = <&tlv320adc_pins>;
ti,mic-bias-source = <1>; /* VREF x 1.096 */
ti,vref-source = <0>; /* 2.75V */
ti,pdm-edge-select = <0 1 0 1>;
ti,gpi-config = <0 0 0 0>;
ti,gpio-config = <0 0>;
ti,gpo-config-1 = <0 0>;
ti,gpo-config-2 = <0 0>;
reset-gpios = <&gpio5 8 GPIO_ACTIVE_HIGH>;
port {
codec_0_ep: endpoint {
remote-endpoint = <&mcasp1_ep0>;
dai-tdm-slot-num = <8>;
dai-tdm-slot-width = <32>;
dai-tdm-slot-tx-mask = <1 1 1 1 0 0 0 0>;
dai-tdm-slot-rx-mask = <1 1 1 1 0 0 0 0>;
tlv320adc5140_4d: tlv320adc5140@4d {
reg = <0x4d>;
port {
codec_1_ep: endpoint {
remote-endpoint = <&mcasp1_ep1>;
dai-tdm-slot-tx-mask = <0 0 0 0 1 1 1 1>;
dai-tdm-slot-rx-mask = <0 0 0 0 1 1 1 1>;
&mcasp1 {
pinctrl-0 = <&mcasp1_pins>;
status = "okay";
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <8>;
/* 4 serializers */
/* 0: INACTIVE, 1: TX, 2: RX */
serial-dir = < 0 0 2 0 >;
tx-num-evt = <1>;
rx-num-evt = <1>;
mcasp1_port0: port@1 {
mcasp1_ep0: endpoint {
remote-endpoint = <&codec_0_ep>;
dai-format = "dsp_b";
frame-master;
bitclock-master;
bitclock-inversion; // Optional flag, preserved
mcasp1_port1: port@2 {
mcasp1_ep1: endpoint {
remote-endpoint = <&codec_1_ep>;
frame-master;
bitclock-master;
