Part Number: INA1650-Q1
Other Parts Discussed in Thread: INA1651, TPS709
Dears, good morning, I had previously asked a question about the INA1650-Q1, thank you again.
You'll remember this INA1651 will be deployed in single supply mode.
Hence, I've a couple of other questions, as I'm in the process to design the relevant power supply stage:
- Will the PSRR capabilities of the INA1651 be worse / same / better, due to single supply mode (against dual supply) ?
- Reason of this question is: the only LDO regulator I've found for this application (fairly high voltage, low current) has an output voltage noise of 100uV, and a PSRR which gets worse for higher frequencies of the audio spectrum. I realize difficult question, but i'd like to estimate if this level of noise will somewhat affect the otherwise great INA performances.
Thank you very much in advance
Cheers
Matteo
