Other Parts Discussed in Thread: TAS5142, TAS5342A,
1. What is the formula for the relationship between Over Current Limit value and resistance value for TAS5342A, TAS5342LA and TAS5142?
I checked the data sheet, but I could only find the table of OC vs ROC. Also, the data sheet says "See the Electrical Characteristics of this data sheet for information on the correlation between programming-resistor value and the OC threshold." ”, but the formula could not be found in Electrical Characteristics.
2. TAS5342A, TAS5342LA
In the data sheet "6.3 Recommended Operating Conditions," it is stated that Roc_max=47kOhm, but is there any problem if Roc_max>47kOhm to reduce the value of overcurrent protection?
As the data sheet states as follows, I would like to know if my question is feasible. Setting the OC threshold too low might cause issues such as lack of enough output power and/or unexpected shutdowns due to too-sensitive overload detection.
Nishie
