TLV320AIC3254: DSP for Acoustic Echo Cancellation
Part Number: TLV320AIC3254
Other Parts Discussed in Thread: PUREPATHCONSOLE, PUREPATHSTUDIO
We are looking for a cost-effective codec with at least 2 ADCs and 2 DACs, and a DSP capable of Acoustic Echo Cancellation (AEC).
We were looking at the TLV320AIC3254 codec and it seems to fit.
Our questions are: Is this codec suitable for our purpose?
Is it possible to implement ANC and AEC with this chip?
Does it come with a pre-built AEC algorithm?
Are there any other codecs better suited for AEC?
Is there any license for the algorithm and/or the PUREPATHCONSOLE software?
We appreciate your guidance in helping us identify the optimal solution.
  • Hi Lahoussine,
    We recommend that customers host the AEC/ANC algorithm on a separate system. The miniDSP codecs we have are pretty old and struggle with implementing AEC/ANC effectively. There is already a known limitation that the sample rate must be 8kHz. The cancellation ability is also lacking to modern expectations.
    There is not an AEC algorithm pre-built that is available. But if you do choose this device and get an algorithm working (for any case) there is no licensing required nor is there a license for PUREPATHSTUDIO.
    Jeff McPherson
