TLV320AIC3110: TLV320AIC3110
Part Number: TLV320AIC3110
Dear Sir,
The I2C Master is now working fine on our customized board. We need the codec I2C configuration script in record mode. Could you please provide it?
Samudralankaiah
  • Hi Samudralankaiah,
    Here is a reference script from the EVM. It contains the set up for recording.
    #			--------------------------------------------------------------- page 0 is selected
    w 30 00 00
    #			 s/w reset
    > 01
    #			 PLL_clkin = BCLK,codec_clkin = PLL_CLK
    w 30 04 07
    > 91
    > 20
    > 00
    > 00
    #			 mode is i2s,wordlength is 16
    w 30 1b 00
    #			 NDAC is powered up and set to 4
    w 30 0b 84
    #			 MDAC is powered up and set to 4
    > 84
    w 30 12 84
    > 84
    #			 DOSR = 128, DOSR(9:8) = 0
    > 00
    #			             DOSR(7:0) = 128
    > 80
    #			 DAC => volume control thru pin disable
    w 30 74 00
    #			 DAC => drc disable, th and hy
    w 30 44 00
    #			 DAC => 0 db gain left
    w 30 41 00
    #			 DAC => 0 db gain right
    > 00
    #			--------------------------------------------------------------- page 1 is selected
    w 30 00 01
    #			 De-pop, Power on = 800 ms, Step time = 4 ms
    w 30 21 4e
    #			 HPL and HPR powered up
    w 30 1f c2
    #			 LDAC routed to HPL, RDAC routed to HPR
    w 30 23 44
    #			 HPL unmute and gain 1db
    w 30 28 0e
    #			 HPR unmute and gain 1db
    > 0e
    #			 No attenuation on HP
    w 30 24 00
    w 30 25 00
    #			 MIC BIAS = AVDD
    w 30 2e 0b
    #			 MICPGA P = MIC 10k
    w 30 30 40
    #			 MICPGA M - CM 10k
    > 40
    w 30 00 00
    #			 select DAC DSP mode 11 & enable adaptive filter
    w 30 3c 0b
    w 30 00 08
    w 30 01 04
    w 30 00 00
    #			 POWERUP DAC left and right channels (soft step disable)
    w 30 3f d6
    #			 UNMUTE DAC left and right channels
    > 00
    #			 POWERUP ADC channel
    w 30 51 80
    #			 UNMUTE ADC channel
    > 00
    w 30 00 01
    #			 Unmute Class-D Left
    w 30 2a 1c
    #			 Unmute Class-D Right
    w 30 2b 1c
    #			 Power-up Class-D drivers
    w 30 20 c6
    Jeff McPherson
