Other Parts Discussed in Thread: INA1651
Dear all, as follow up since my last preliminary question on that, I've designed the balanced XLR driver stage, based on the information from the datasheet.
As you can see from the picture below, I plan to connect the VMID Output to both REF_A/B and COM_A/B.
Furthermore, my single ended audio signal would go to the IN +A input. IN +B input to ground.
IN -A input tied to OUT_B; IN -B input tied to OUT_A.
Is this all correct ? Are you seeing any warning / issue ?
Thanks so much in advance !
Cheers
Matteo
