TLV320AIC3104EVM-K: Windows 10 based GUI issue
Part Number: TLV320AIC3104EVM-K
We are unable to load the GUI for the Audio Codec EVK.
We tried all possible methods. But not able to comeup withn the GUI.
Since it is a company laptop, we are not allowed for a CMD with Admin access.
It would be best if we could get a direct software with windows 10 driver.
  • Hi Prajit,
    I've attached the extracted/installed files for you.
    You will also need to install NI 2019 F2 Labview Runtime Manager.
    Jeff McPherson
  • Hey Jeff,
    I tried. But no luck... Can you kindly suggest an alternative. Or any TI Application Engineer can help us to resolve the issue.
    I tried installing the package. For reference, please find the attached NI packages:
    This is the Device Manager able to see:
    And the GUI Window showing this:
    And this is the EVK Module we have:
    Is the codec appearing in your audio devices? Did you install the driver found in the installation package?
    Also double check that the binary for the NI package is in the right install path. Without running the actual installer, it may have trouble identifying where the NI package is.
    Jeff McPherson
