I am writing to request some additional information regarding the TAS6422-Q1 audio amplifier IC that is not available in the current datasheet.
We are considering using this IC in an upcoming project and need some more details to ensure it meets our requirements. Please see the requirements below
Distortion rate shall be 0.05% or less - Could not find the distortion rate directly from datasheet and it gives only THD+N which is 0.03%.
Residual noise 0.2mVrms or less - Could not find it. However, datasheet specifies the output noise as 42 µVRMS
Channel Balance Within ±0.5dB - Channel Balance information is not available in datasheet.
Could you please help to get the above three parameters for TAS6422-Q1?
