Part Number: TLV320AIC3104
Other Parts Discussed in Thread: PCM3168A-Q1, PCM3168A, TAA5212-Q1
Dears,
I am currently exploring audio codec options similar in functionality to PN: CS42888-DQZ. If you have any recommended alternatives or compatible components with similar specifications, I would greatly appreciate it if you could share the details for consideration in our ongoing project.
In case no direct alternative is available from TI, I would also like to inquire whether you have any end-to-end solutions suitable for car infotainment systems, specifically supporting the following output requirements:
4 × 45W speaker outputs
2 × 75W subwoofer outputs
The system will receive I2S audio signals from the SoC, which need to be processed through a compatible audio codec and then fed into a power amplifier meeting the above output specs.
If you have any evaluation kits (EVKs) or development platforms that align with this requirement, kindly let me know. Your suggestions and technical guidance would be highly appreciated.
Looking forward to your response.
Thank you and best regards,
Santhosh
