Part Number: LMV1091
Other Parts Discussed in Thread: TLV320AIC3204, TAS2563, TAS2572, TAS2781, TAS2780
Hi Team,
During my evaluation of active noise cancellation (ANC) solutions, I came across the LMV1091 — a Dual Input, Far Field Noise Suppression Microphone Amplifier. I would appreciate your clarification on the following points:
Application for ANC:
How effectively can the LMV1091 contribute to achieving active noise cancellation?
Specifically, can it be used for front-end far-field noise suppression as part of an ANC system, or would it require additional processing stages?
Compatibility:
Can the LMV1091 interface seamlessly with the i.MX6ULL processor and the TLV320AIC3204 audio codec?
Are there any specific interface or signal conditioning considerations when connecting the LMV1091 outputs to the TLV320AIC3204 inputs?
Additional Requirements:
Apart from the LMV1091, what other system components (DSPs, additional filtering stages, etc.) would be required to implement a complete ANC solution?
Any recommended design guidelines or application notes would be helpful.
Please provide your technical insights on these aspects. If available, sharing a typical application block diagram would also be appreciated.
Looking forward to your detailed inputs.
