Hi expert,
Could you please help confirm if the following charts can be provided under a 4Ω load with Vbat at 5V?
1. Power vs. Efficiency
2. Frequency vs. THD+N (20Hz–20kHz @ 5W)
BR,
Zach
Hi expert,
BR,
Zach
Hi Zach,
As this data is not provided in datasheet, could you please help to answer below questions firstly and also clarify why above data is required?
1. What is your customer name to use TAS2120?
2. What is their end equipment application with TAS2120?
3. What is the project name which uses TAS2120?
4. What is the actual volume to use TAS2120 in this project?
BR,
