is TLV320AIC3268 supported by PurePath Console 3? if yes, after I installed it, why can't I find the EVM app? how can I get the app? if not, which software should I get? thank you.
Hi Stone,
The EVM user guide says that AIC3268 is supported for PurePath Console 2. You can download PPC3 by using the same link for PPC3, but install version 2 instead of version 3.
For the miniDSP configurations you'll need PurePath Studio. https://www.ti.com/secureresources/PUREPATHSTUDIO
Jeff McPherson
Hi sir,
thank you for your helpful answer. I have another question:
when I read the example of script writing, for the read command, the last byte is how many bytes will be read, why there is a letter follow the byte? for example 02e, 06b, how is it calculated out? thank you.
r30 03 02e // read 2 bytes from device 30 at address 03
r 30 03 06b // read 6 bytes from device 30 at address 03
Sorry I cannot paste pictures into this topic, please just check the exact code in above 2 lines.
Hi Stone,
Can you help point me to where you are seeing this in the script? Which script is this from?
The letters shouldn't be there from my understanding. The third byte is the number of bytes to be read as you correctly pointed out.
Jeff McPherson
Hi Jeff,
I encountered another problem about installing PurePath Studio, either Home Audio or Portable Audio version, after I started the installation, it popped out a message ask for .net framework 2.0 installation, after I clicked OK, it popped another page tell me the installation wizard was interrupted, and I had to click the finish button, and the installation aborted. please check following pictures.
Thank you very much for your advice!
Hi Stone,
See here to see if you can work around getting .net framework 2.0: https://answers.microsoft.com/en-us/windows/forum/all/how-to-install-net-framework-20-in-windows-10/61616e06-5785-4cac-a030-b59d1fe6ec2c
Unfortunately the EVM is obsolete so it is not available.
Jeff McPherson
