Hi all,
We designed the schematic using the TLV320AIC3007, but in a design refinement it doesn't output audio anymore .
Here's the altered schematic, where SAI5 is a 1.8V level signal.
Here's the schematic before this, which uses the SAI2 signal at 3.3V levels. The audio works during debugging, but only when you press the answer button on the headset can you hear the sound clearly.
Can you help check the altered schematic for design errors? What can be changed to make it work.
With best regards.
Xavier
