When playing a 1KHz single sound source, the codec output waveform is as follows. Please help me find out what the reason is. Thank you.
I notice that your SPK1 and SPK2 may be connected incorrectly, RIGHT_LOM and RIGHT_LOP will be one (-) and (+) differential pair of line outs to SPK1, and LEFT_LOM and LEFT_LOP will be the pair to SPK2. Potentially your issue we are seeing is due to the scope/speaker trying to take a differential pair of two very similar signals.
Let me know if switching these connections helps.
Mir
Your schematic looks to be connected incorrectly at the outputs. You confused L/R with P/M outputs. It may not be an easy fix with the measurements because of the filters you have. I drew out the lines showing which output goes to which speaker, note that blue=right output, and purple=left output:
Let me know if this fixes your issue.
Mir
This looks better! Let me know if you are still having issues with the device.
Mir
HI,
The schematic diagram has always been correct. The one uploaded earlier may not look clear because the signal was not pulled apart, but the problem has always existed. Please help me continue to analyze it. Thank you!
Okay, we can figure this out. Can you also attach your i2c config or register dump?
Mir
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 00 00 00 91 20 1e 00 0a 00 20 00 01 00 00 00 20 ...? ?.?. .?... 10: 20 ff ff 00 78 78 00 78 78 06 00 fe 00 00 fe 00 ...xx.xx?.?..?. 20: 00 00 00 00 00 c0 00 00 40 00 00 0a 0a 2f 2f af .....?..@..??//? 30: 00 00 00 0f 2f 2f af 00 00 00 0f 00 00 00 2f 2f ...?//?...?...// 40: af 0f 00 00 00 2f 2f af 0f 2f 2f af 2f 2f af 0b ??...//??//?//?? 50: 2f 2f af 00 00 00 0b 00 00 00 2f 2f af 0b fe 0c //?...?...//???? 60: 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 ......?......... 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 80: 00 00 00 91 20 1e 00 0a 00 20 00 01 00 00 00 20 ...? ?.?. .?... 90: 20 ff ff 00 78 78 00 78 78 06 00 fe 00 00 fe 00 ...xx.xx?.?..?. a0: 00 00 00 00 00 c0 00 00 40 00 00 0a 0a 2f 2f af .....?..@..??//? b0: 00 00 00 0f 2f 2f af 00 00 00 0f 00 00 00 2f 2f ...?//?...?...// c0: af 0f 00 00 00 2f 2f af 0f 2f 2f af 2f 2f af 0b ??...//??//?//?? d0: 2f 2f af 00 00 00 0b 00 00 00 2f 2f af 0b fe 0c //?...?...//???? e0: 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 ......?......... f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
I looked at the register dump, I do not see anything obviously wrong. Can you show where you are measuring this output, and what are you sending to input to the device? Can you explain what the issue is?
Mir
For reference, here is commented reg dump:
03 91 #PLL enabled, q=2, p=1 04 20 #J = 8 05 1e #111 1000 0000 = D= 1920 07 0a #left dac plays left channel data, right dac plays right channel data 09 20 #i2s mode, 24 bits 0b 01 #r=1 0f 20 #left adc pga is not muted, gain=16dB 10 20 #right adc pga is not muted, gain=16dB 11 ff #mic2l is not connected, mic2r/line2r not connected to left adc pga 12 ff #lic2l/line2l, mic2r/line2r is not connected to right adc pga 15 78 #mic1rp/line1rp is single ended mode, line1r is not connectred to left adc pga 16 00 #mic1rp/line1rp is single ended mode, level control gain =0dB, line1r is conected to right adc pga, powered down 18 78 #mic1lp/line1lp is single ended mode, line1l is not connected to right adc pga 19 06 #micbias output powered down 1a 00 #agc disabled 1b fe #default max gain for l agc 1e fe #default max gain for r agc 25 c0 #left and right dac powered up 28 40 #output common mode voltage = 1.5V 2b 0a #left dac channel not muted, gain = -5dB 2c 0a #right dac chanel not muted, gain = -5dB 2d 2f #reserved 2e 2f #pga_L not routed to hplout 2f af #DAC_L1 is routed to HPLOUT, volume control = 010 1111 33 0f #HPLOUT level control=0dB,not muted, fully powered up 35 2f #PGA_L is not routed to HPLCOM 36 af #DAC_L1 is routed to HPLCOM, volume ctrl = 010 1111 3a 0f #HPLCOM level control = 0dB, not muted, fully powered up 3f 2f #PGA_R is not routed to HPROUT 40 af #DAC_R1 is routed to HPROUT, volume ctrl = 010 1111 41 0f #HPROUT level = 0dB, not muted, fully powered up 46 2f #PGA_R is not routed to HPRCOM 47 af #DAC_R1 is routed to HPRCOM, volume control = 010 1111 48 0f #HPRCOM level = 0dB, not muted, fully powered up 51 2f #PGA_L not routed to left lop/m 52 af #DAC_L1 is routed to LEFT_LOP/M, volume control = 010 1111 56 0b #left_lop/m output level = 0dB, not muted, fully powered up 5b 2f #pga_r not routed to right lop/m 5c af #DAC_R1 is routed to right_lop/m, volume control = 010 1111 5d 0b #RIGHT_LOP/M level = 0dB, not muted, fully powered up 5e fe #l+r dac fully powered up, l+r lop/m fully powered up, hpl/hprout fully powered up 5f 0c #hpl+hprcom fully powered up
