Other Parts Discussed in Thread: TLV320DAC3100
I am using the TLV320DAC3100 codec in my application, and I need to implement the following functionality:
- When audio is playing through the speakers and headphones are plugged in, the audio should automatically switch to the headphones, and the speakers should be muted.
- When the headphones are unplugged, the audio should switch back to the speakers, and the headphones should be muted.
I know the codec supports headphone jack detection and has programmable audio routing, as mentioned in the datasheet. However, I am a bit unclear about how to configure the codec registers and handle the headphone detection signal to achieve this functionality.
Can you please provide:
- A step-by-step guide for configuring the TLV320DAC3100 to enable this feature?
- A code snippet (I2C commands or pseudocode) for:
- Detecting headphone insertion/removal.
- Switching the audio path dynamically between speakers and headphones.
Additionally, if there are any specific register settings or application notes/documents you recommend referring to, please let me know.
Thank you for your support!
