TLV320DAC3100: Audio codec clock parameter caluclation
Part Number: TLV320DAC3100
Dear Team,
We are using TLV320DAC3100IRHBR audio codec with our custom platform, we are using below mentioned kernel driver driver
URL: https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/sound/soc/codecs/tlv320aic31xx.c
The above mentioned kernel driver will only supports some of the clock rates under aic31xx_divs[] structure, we want to support other clock rates (for example 6M, 12M, 26M, etc), for these custom clocks kindly provide formula to calculate below mentioned parameters
struct aic31xx_rate_divs {
        u32 mclk_p;
        u32 rate;
        u8 pll_j;
        u16 pll_d;
        u16 dosr;
        u8 ndac;
        u8 mdac;
        u8 aosr;
        u8 nadc;
        u8 madc;
Nikhil K
  • Hi Nikhil,
    I would recommend you read section 6.3.11 of the DAC3100 datasheet, this explains how the clock tree works. I am happy to help more or double check your math for each clock rate you want to support.
    The parameters here:
    mclk_p = MCLK rate
    rate = sample rate (FSYNC rate)
    pll_j = J of J.D
    pll_d = D of J.D, needs to be 4 digits (if J.D is 5.2, then D=2000)
    dosr = should be 128 (DAC OSR)
    aosr = should be 128 (ADC OSR)
    Mir
